Below is the GDB backtrace information:
(gdb) run
Starting program: /home/tarun/Documents/wip/TransferToViper/ParaView-5.6.0-MPI-OpenGL-VTK-Linux-64bit-UoH/bin/paraview
process 15197 is executing new program: /home/tarun/Documents/wip/TransferToViper/ParaView-5.6.0-MPI-OpenGL-VTK-Linux-64bit-UoH/lib/paraview
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffc2790700 (LWP 15204)]
Fontconfig warning: "/etc/fonts/fonts.conf", line 146: blank doesn't take any effect anymore. please remove it from your fonts.conf
Program received signal SIGABRT, Aborted.
0x00007fffdb1cec37 in __GI_raise (sig=sig@entry=6)
at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) backtrace
#0 0x00007fffdb1cec37 in __GI_raise (sig=sig@entry=6)
#1 0x00007fffdb1d2028 in __GI_abort () at abort.c:89
#2 0x00007fffeaf7bc6a in vtkXOpenGLRenderWindow::CreateAWindow (
this=0x3087190)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.cxx:468
#3 0x00007fffeaec68a4 in vtkOpenGLRenderWindow::CreateHardwareOffScreenWindow
(this=0x3087190, width=300, height=300)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx:1983
#4 0x00007fffeaf7d148 in vtkXOpenGLRenderWindow::CreateOffScreenWindow (
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.cxx:794
#5 0x00007fffeaf7d594 in vtkXOpenGLRenderWindow::Initialize (this=0x3087190)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.cxx:871
#6 0x00007fffeaec7e65 in vtkOpenGLRenderWindow::SupportsOpenGL (
this=0x3085660)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx:2427
#7 0x00007ffff2b76ef3 in vtkPVRenderingCapabilitiesInformation::GetLocalCapabil---Type <return> to continue, or q <return> to quit---
ities ()
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderingCapabilitiesInformation.cxx:126
#8 0x00007ffff2b77027 in vtkPVRenderingCapabilitiesInformation::CopyFromObject
(this=0x3083f00)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderingCapabilitiesInformation.cxx:178
#9 0x00007ffff17054ca in vtkPVSessionCore::GatherInformationInternal (
this=0xc9da80, information=0x3083f00, globalid=0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:783
#10 0x00007ffff17057bd in vtkPVSessionCore::GatherInformation (this=0xc9da80,
location=4, information=0x3083f00, globalid=0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:821
#11 0x00007ffff1701078 in vtkPVSessionBase::GatherInformation (this=0xc9e680,
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ServerImplementation/Core/vtkPVSessionBase.cxx:243
#12 0x00007ffff79ce790 in pqDefaultViewBehavior::onServerCreation (
this=0xc9a290, server=0xe79880)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/ApplicationComponents/pqDefaultViewBehavior.cxx:131
#13 0x00007ffff7a8cb64 in pqDefaultViewBehavior::qt_static_metacall (
_o=0xc9a290, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0x7fffffffcd60)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Qt/ApplicationComponents/moc_pqDefaultViewBehavior.cpp:83
#14 0x00007ffff3c3b786 in QMetaObject::activate(QObject*, int, int, void**) ()
from /home/tarun/Documents/wip/TransferToViper/ParaView-5.6.0-MPI-OpenGL-VTK-Linux-64bit-UoH/lib/libQt5Core.so.5
#15 0x00007ffff6a6a8c7 in pqServerManagerModel::serverAdded (this=0x7d6190,
_t1=0xe79880)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Qt/Core/moc_pqServerManagerModel.cpp:566
#16 0x00007ffff6a32634 in pqServerManagerModel::onConnectionCreated (
this=0x7d6190, id=1)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/Core/pqServerManagerModel.cxx:503
#17 0x00007ffff6a69ec5 in pqServerManagerModel::qt_static_metacall (
_o=0x7d6190, _c=QMetaObject::InvokeMetaMethod, _id=36, _a=0x7fffffffcfa0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Qt/Core/moc_pqServerManagerModel.cpp:270
#18 0x00007ffff3c3b786 in QMetaObject::activate(QObject*, int, int, void**) ()
from /home/tarun/Documents/wip/TransferToViper/ParaView-5.6.0-MPI-OpenGL-VTK----Type <return> to continue, or q <return> to quit---
#19 0x00007ffff6a6bc37 in pqServerManagerObserver::connectionCreated (
this=0x7d3f40, _t1=1)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Qt/Core/moc_pqServerManagerObserver.cpp:280
#20 0x00007ffff6a361be in pqServerManagerObserver::connectionCreated (
this=0x7d3f40, callData=0x7d20a0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/Core/pqServerManagerObserver.cxx:110
#21 0x00007ffff6a6b644 in pqServerManagerObserver::qt_static_metacall (
_o=0x7d3f40, _c=QMetaObject::InvokeMetaMethod, _id=10, _a=0x7fffffffd1e0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Qt/Core/moc_pqServerManagerObserver.cpp:144
#22 0x00007ffff3c3b786 in QMetaObject::activate(QObject*, int, int, void**) ()
#23 0x00007ffff377e415 in vtkQtConnection::EmitExecute (this=0x7eab30, _t1=
0x7d2060, _t2=68, _t3=0x0, _t4=0x7d20a0, _t5=0x7cb4c0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/VTK/GUISupport/Qt/moc_vtkQtConnection.cpp:141
#24 0x00007ffff3766998 in vtkQtConnection::Execute (this=0x7eab30,
caller=0x7d2060, e=68, call_data=0x7d20a0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/s---Type <return> to continue, or q <return> to quit---
rc/VTK/GUISupport/Qt/vtkQtConnection.cxx:72
#25 0x00007ffff3766938 in vtkQtConnection::DoCallback (vtk_obj=0x7d2060,
event=68, client_data=0x7eab30, call_data=0x7d20a0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/GUISupport/Qt/vtkQtConnection.cxx:62
#26 0x00007fffdc7a504b in vtkCallbackCommand::Execute (this=0x7cb4c0,
caller=0x7d2060, event=68, callData=0x7d20a0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Common/Core/vtkCallbackCommand.cxx:42
#27 0x00007fffdca58e8e in vtkSubjectHelper::InvokeEvent (this=0x7d5460,
event=68, callData=0x7d20a0, self=0x7d2060)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Common/Core/vtkObject.cxx:616
#28 0x00007fffdca59395 in vtkObject::InvokeEvent (this=0x7d2060, event=68,
callData=0x7d20a0)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/VTK/Common/Core/vtkObject.cxx:785
#29 0x00007ffff1374cac in vtkProcessModule::RegisterSession (this=0x7d2060,
session=0xc9e680)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Core/vtkProcessModule.cxx:387
#30 0x00007ffff1c2404b in vtkSMSession::ConnectToSelf (timeout=60)
rc/ParaViewCore/ServerManager/Core/vtkSMSession.cxx:311
#31 0x00007ffff69f0f3c in pqObjectBuilder::createServer (this=0x7d3e20,
resource=..., connectionTimeout=60)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/Core/pqObjectBuilder.cxx:671
#32 0x00007ffff796ed69 in pqAlwaysConnectedBehavior::serverCheck (this=
0xc9bb50)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/ApplicationComponents/pqAlwaysConnectedBehavior.cxx:81
#33 0x00007ffff796ebe4 in pqAlwaysConnectedBehavior::pqAlwaysConnectedBehavior
(this=0xc9bb50, parentObject=0xc98670)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/ApplicationComponents/pqAlwaysConnectedBehavior.cxx:52
#34 0x00007ffff7a02880 in pqParaViewBehaviors::pqParaViewBehaviors (this=
0xc98670, mainWindow=0x806c20, parentObject=0x806c20)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Qt/ApplicationComponents/pqParaViewBehaviors.cxx:221
#35 0x0000000000412faa in ParaViewMainWindow::ParaViewMainWindow (this=
0x806c20)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/src/Applications/ParaView/ParaViewMainWindow.cxx:295
#36 0x0000000000410a41 in pqparaviewInitializer::Initialize (
this=0x7fffffffdcb0, argc=1, argv=0x7fffffffde18)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Applications/ParaView/pqparaviewInitializer.cxx:124
#37 0x000000000041040e in main (argc=1, argv=0x7fffffffde18)
at /home/u602026/VoxFE/ParaViewPackage2/paraview_build/superbuild/paraview/build/Applications/ParaView/paraview_main.cxx:113
(gdb)
