I have a python script that I am using to create image files. The script uses the extract block filter. The python command for that filter looks like the following.
extractBlock1 = ExtractBlock(Input=Input_Source) extractBlock1.BlockIndices = [x, y, z, …]
How do I determine what block index goes with each block name? For example, I am able to determine what blocks are in the exodus file.
exo.ElementBlocks.Available
But this does not return the index value. How do I determine what index value is associated with each block name returned by the .available?
Just to be clear, you have a composite dataset containing vtkImageData objects which each have a unique name and you would like to save those out to their own files? I believe ParaView’s native image data writer can handle this… If you are using some custom format there are a few ways you could grab the name:
Grab the name while scripting
To get the name of any block in an input composite dataset:
from paraview.simple import *
from paraview.servermanager import Fetch
import vtk
# Find the server manager source on the pipeline
src = FindSource('inputData')
# Get the VTK data object from that source
obj = Fetch(src)
# Grab the name for any index
index = 0
name = obj.GetMetaData(index).Get(vtk.vtkCompositeDataSet.NAME())
Make a custom writer plugin
Using ParaView 5.6’s new Python Algorithm plugin capability, you could create a custom writer plugin much like an example I demonstrate in this snippet which I have updated to pass the composite dataset’s names here. Note that these base classes are fully implemented in PVGeo.
@smproxy.writer(extensions="imgfmt", file_description="Write Custom ImageData", support_reload=False)
@smproperty.input(name="Input", port_index=0)
@smdomain.datatype(dataTypes=["vtkImageData"], composite_data_supported=True)
class WriteCustomImageData(WriterBase):
"""This is an example of how to make your own file writer!
.. _PVGeo: http://pvgeo.org
.. _Bane Sullivan: http://banesullivan.com
def __init__(self):
WriterBase.__init__(self, inputType='vtkImageData')
self.__delimiter = ','
def PerformWriteOut(self, inputDataObject, filename, objectName):
"""Perfrom the file write to the given FileName with the given data
object. The super class handles all the complicated stuff.
fname = filename.split('.')
fname = '.'.join(fname[0:-1]) + '_%s.%s' % (objectName, fname[-1])
writer = vtk.vtkXMLImageDataWriter()
writer.SetFileName(fname)
writer.SetInputDataObject(inputDataObject)
writer.Write()
# Success for pipeline
return 1
@smproperty.stringvector(name="FileName", panel_visibility="never")
@smdomain.filelist()
def SetFileName(self, fname):
"""Specify filename for the file to write."""
WriterBase.SetFileName(self, fname)
I am facing the same problem right now - I want to extract the block indices from my multiblock dataset using python.
I have already tried the solutions you have mentioned but somehow it´s not working for me. I keep getting an error:
File "C:\Program Files\ParaView 5.8.0-MPI-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\paraview\servermanager.py", line 1688, in OutputPort
if outputPort >= proxy.GetNumberOfOutputPorts():
AttributeError: 'NoneType' object has no attribute 'GetNumberOfOutputPorts'
