Howdy,
The new OSPRay path tracer in ParaView 5.5.0 has a mode in which each cell gets a material assigned via colormapping. To use it:
- choose “Value Indexed” for the OSPRay Material instead of any of the individual material names.
- pick an array to material map, for example “MaterialIds” that you will get with many .obj files
- set up a categorical color map with annotations that are material names.
With .obj files there is a field aligned array “MaterialNames” that has all of the material names referenced by the .obj in it. You can see it in the spreadsheet view. You could manually create a lookup table from it, but the following script will create a lookup table automatically (copy and paste it into the Python Shell).
anObject = GetActiveSource()
vtklevel = anObject.GetClientSideObject()
lut = GetColorTransferFunction('MaterialIds')
arr = vtklevel.GetOutput().GetFieldData().GetAbstractArray("MaterialNames")
lut.InterpretValuesAsCategories = 1
ll = []
for x in range(0, arr.GetNumberOfTuples()):
ll.append(str(x))
ll.append(arr.GetValue(x))
lut.Annotations = ll
hth
