Issue importing paraview.simple module with Anaconda Prompt
Hello, I am trying to import the paraview.simple module using Anaconda Prompt. I’ve set my system variables (both PATH and PYTHONPATH) to the following:
C:\Program Files\ParaView 5.8.0-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\win32\libs (Location of the only .lib file in the whole ParaView 5.8.0-Windows-Python3.7-msvc2015-64bit folder)
C:\Program Files\ParaView 5.8.0-Windows-Python3.7-msvc2015-64bit\bin (Location of ospray .dll files including ospray_module_ispc.dll)
However, I still get this error about 30 times in a row:
#osp: INITIALIZATION ERROR --> could not open module lib ospray_module_ispc: The specified module could not be found.
Someone else is also having the same issue here.
I looked at this discussion as well as this one. The latter said he fixed it by adding a path directly to the .pth file, but I’m not sure how to do this and am not sure if our issue is the same.
Hey! Person with this same problem here.
I used this setup to attempt to fix the osprey issue using the .pth file… It um, didn’t work for me, but perhaps it’ll help you!
If you come up with a solution I’d love to hear what fixes it!
Thanks for sharing! Well, I’m not familiar at all with .pth files and there is an existing one already in the ParaView site-packages folder with this content:
# .pth file for the PyWin32 extensions
win32
win32\lib
Pythonwin
# Entries needed for a "portable" installations, where the post_install script
# isn't run, which would normally copy the pywin32 core DLL files to either
# the top of the python directory.
# We just stick the source of these DLLs directly on the PATH.
import os;os.environ["PATH"]+=(';'+os.path.join(sitedir,"pywin32_system32"))
I’m not too sure how to alter it and I’m kind of scared to haha. If you have any ideas please share!
