Local axes are displayed in the nodes, not in elements
Hello. I currently try to visualize exodus file, obtained as a result from MOOSE framework. There is an issue with local axes displaying: they are displayed at the nodes, but i need it to be assingned to elemetns.
small_strain_bending_out1.e (81.7 KB)
Help me please to get the correct view.
Use CellCenters filter
Thank you. Does then a glyph filter must be inside CellCenters?
If it is true, then i can’t acces to my data “local_axis_x”, which was available when I used the glyph directly.
Use PointDataToCellData first, it will interpolate.
Thank you, it works
