I have been trying to build ParaView to test the custom apps examples here on MacOS.
I have followed the site instructions for the superbuild here.
I have had several problems with the Qt build, after some tweaking here is the result
These are the steps I have done:
$ mkdir pv
$ cd pv
$ git clone https://gitlab.kitware.com/paraview/paraview-superbuild.git
$ cd paraview-superbuild
$ git fetch origin # ensure you have the latest state from the main repo
$ git submodule update
$ cd ..
$ mkdir paraview_build
$ cd paraview_build
$ cmake ../paraview-superbuild
$ ccmake -DCMAKE_OSX_SDK=macosx10.14 ../paraview-superbuild
I enabled the CMake variables:
ENABLE_qt5
ENABLE_python
ENABLE_python2
Then ran:
$ make
First, I got the error
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/platformsupport/fontdatabases/mac/qfontengine_coretext.mm:833:20: error: qualified reference to 'QFixed' is a constructor name rather than a type in this context
return QFixed::QFixed(int(CTFontGetUnitsPerEm(ctfont)));
Which was solved by going to the file /Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/platformsupport/fontdatabases/mac/qfontengine_coretext.mm and remove QFixed:: prefix in line 833
After that, I re run make and got a lot more errors
~ cd Desktop/dev/pv
➜ pv ls
paraview-superbuild paraview_build
➜ pv cd paraview_build
➜ paraview_build clear
➜ paraview_build ls
CMakeCache.txt CTestCustom.cmake DartConfiguration.tcl Testing cpack install tests
CMakeFiles CTestTestfile.cmake Makefile cmake_install.cmake downloads superbuild
➜ paraview_build make
[ 3%] Built target cxx11_check
[ 14%] Built target szip
[ 24%] Built target zlib
[ 37%] Built target hdf5
[ 46%] Built target cxx11
[ 56%] Built target nlohmannjson
[ 67%] Built target python2
[ 79%] Built target python
[ 80%] Performing build step for 'qt5'
Makefile:2392: warning: overriding commands for target `../../lib/QtGui.framework/Versions/5/Headers/QGenericPlugin'
Makefile:2024: warning: ignoring old commands for target `../../lib/QtGui.framework/Versions/5/Headers/QGenericPlugin'
Makefile:2396: warning: overriding commands for target `../../lib/QtGui.framework/Versions/5/Headers/QGenericPluginFactory'
Makefile:2020: warning: ignoring old commands for target `../../lib/QtGui.framework/Versions/5/Headers/QGenericPluginFactory'
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:235:9: error: unknown type name 'my_bool'
my_bool nullIndicator;
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:986:13: error: use of undeclared identifier 'my_bool'
QVector<my_bool> nullVector;
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1000:9: error: use of undeclared identifier 'nullVector'
nullVector.resize(values.count());
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1007:13: error: use of undeclared identifier 'nullVector'
nullVector[i] = static_cast<my_bool>(val.isNull());
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1007:41: error: unknown type name 'my_bool'
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1008:34: error: use of undeclared identifier 'nullVector'; did you mean 'nullptr'?
currBind->is_null = &nullVector[i];
nullptr
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1008:33: error: cannot take the address of an rvalue of type 'nullptr_t'
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1104:9: error: unknown type name 'my_bool'
my_bool update_max_length = true;
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:1315:5: error: unknown type name 'my_bool'
my_bool reconnect=false;
In file included from /Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:47:
In file included from /Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtSql/qsqlindex.h:1:
In file included from /Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtSql/../../src/sql/kernel/qsqlindex.h:46:
In file included from /Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtCore/qvector.h:1:
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtCore/../../src/corelib/tools/qvector.h:415:24: error: too many arguments to function call, expected single argument 'sz', have 3 arguments
reallocData(asize, newAlloc, opt);
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/src/plugins/sqldrivers/mysql/qsql_mysql.cpp:399:12: note: in instantiation of member function 'QVector<QMYSQLResultPrivate::QMyField>::resize' requested here
fields.resize(mysql_num_fields(meta));
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtCore/../../src/corelib/tools/qvector.h:296:5: note: 'reallocData' declared here
void reallocData(const int sz) { reallocData(sz, d->alloc); }
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtCore/../../src/corelib/tools/qvector.h:296:54: error: too many arguments to function call, expected single argument 'sz', have 2 arguments
/Users/username/Desktop/dev/pv/paraview_build/superbuild/qt5/src/qtbase/include/QtCore/../../src/corelib/tools/qvector.h:415:5: note: in instantiation of member function 'QVector<QMYSQLResultPrivate::QMyField>::reallocData' requested here
11 errors generated.
make[8]: *** [.obj/qsql_mysql.o] Error 1
make[7]: *** [sub-mysql-make_first] Error 2
make[6]: *** [sub-sqldrivers-make_first] Error 2
make[5]: *** [sub-plugins-make_first] Error 2
make[4]: *** [sub-src-make_first] Error 2
make[3]: *** [module-qtbase-make_first] Error 2
CMake Error at /Users/username/Desktop/dev/pv/paraview_build/superbuild/sb-qt5-build.cmake:47 (message):
Failed with exit code 2
make[2]: *** [superbuild/qt5/stamp/qt5-build] Error 1
make[1]: *** [superbuild/CMakeFiles/qt5.dir/all] Error 2
make: *** [all] Error 2
It seems to be a problem with qsql_mysql.
Any ideas?
