OpenGL problems
I am getting OpenGL support is inadequate problem.
The drivers are installed. Any suggestions on what
to do?
opensuse-15
paraview 5.4.1 64-bit
openGL support inadequate
Your openGL drivers dont support required openGL features
for basic rendering. Application cannot continue.
Please exit and use an older version
Continue at your own risk!
openGL vendor:
openGL version:
openGL renderer:
Are you running in a VM ? What is your gpu ?
There is no VM, also this is just a simple desktop with
I think an i5, no GPU either.
You must have some kind of GPU, even an integrated chipset.
Please post the results of :
glxinfo
lspci
lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:16.3 Serial controller: Intel Corporation 5 Series/3400 Series Chipset KT Controller (rev 06)
00:19.0 Ethernet controller: Intel Corporation 82578DM Gigabit Network Connection (rev 05)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 05)
00:1c.6 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 7 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Q57 Chipset LPC Interface Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev 05)
00:1f.5 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller (rev 05)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 05)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 05)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 05)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 05)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 05)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 05)
glxinfo
******** (sorry a ton of stuff follows)
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
    GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Intel Open Source Technology Center (0x8086)
    Device: Mesa DRI Intel(R) Ironlake Desktop  (0x42)
    Version: 18.0.2
    Accelerated: yes
    Video memory: 1536MB
    Unified memory: yes
    Preferred profile: compat (0x2)
    Max core profile version: 0.0
    Max compat profile version: 2.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 2.0
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) Ironlake Desktop
OpenGL version string: 2.1 Mesa 18.0.2
OpenGL shading language version string: 1.20
OpenGL extensions:
    GL_3DFX_texture_compression_FXT1, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_APPLE_object_purgeable,
    GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility, GL_ARB_arrays_of_arrays,
    GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
    GL_ARB_clip_control, GL_ARB_color_buffer_float,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_copy_buffer,
    GL_ARB_copy_image, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_draw_buffers,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_draw_parameters,
    GL_ARB_shader_group_vote, GL_ARB_shader_objects,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sync,
    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_filter_anisotropic,
    GL_ARB_texture_float, GL_ARB_texture_mirror_clamp_to_edge,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_storage, GL_ARB_texture_swizzle,
    GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
    GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
    GL_ATI_texture_float, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_polygon_offset, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
    GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
    GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
    GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_vertex_array,
    GL_EXT_vertex_array_bgra, GL_IBM_multimode_draw_arrays,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_INGR_blend_func_separate, GL_KHR_blend_equation_advanced,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
    GL_KHR_robustness, GL_MESA_pack_invert, GL_MESA_texture_signed_rgba,
    GL_MESA_window_pos, GL_NV_blend_square, GL_NV_conditional_render,
    GL_NV_depth_clamp, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 18.0.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_discard_framebuffer,
    GL_EXT_draw_buffers, GL_EXT_draw_elements_base_vertex, GL_EXT_frag_depth,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
    GL_EXT_read_format_bgra, GL_EXT_robustness,
    GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
    GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,
    GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
    GL_KHR_debug, GL_KHR_no_error, GL_KHR_robustness, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
    GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
    GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_required_internalformat,
    GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,
    GL_OES_surfaceless_context, GL_OES_texture_3D,
    GL_OES_texture_border_clamp, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_vertex_array_object, GL_OES_vertex_half_float
46 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x022 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x09a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x09b 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x09c 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x09d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09e 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x09f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a0 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a1 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0a2 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0a3 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0a4 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0a5 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0a6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0a7 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a8 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0a9 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0aa 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x0ab 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0ac 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0ad 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ae 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0af 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0b0 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b1 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b2 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0b3 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0b4 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0b5 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0b6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0b7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0b8 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0b9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0ba 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0bb 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x05f 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0bc 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0bd 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0be 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0bf 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0c0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x0c1 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0c2 32 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x0c3 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0c4 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
58 GLXFBConfigs:
0x060  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x061  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x062  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x063  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x064 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x065 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x066 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x067 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x068 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x069 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x06a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x06b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x06c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x06d 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x06e 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x06f 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x070  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x071  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x072 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x073 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x074 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x075 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x076 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x077 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x078  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x079  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x07a  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x07b  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x07c 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x07d 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x07e 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x07f 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x080 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x081 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x082 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x083 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x084 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x085 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x086 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x087 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x088  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x089  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x08a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x08b 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x08c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x08d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x08e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x08f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x090 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x091 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x092 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x093 32 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x094 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x095 32 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x096 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x097 32 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x098 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x099 32 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
try to run ParaView like this :
  • Open Terminal
  • MESA_GL_VERSION_OVERRIDE=3.2 paraview
similar message
CONTINUE AT YOUR OWN RISK!
OpenGL Vendor: Intel Open Source Technology Center
OpenGL Version: 3.2 (Core Profile) Mesa 18.0.2
OpenGL Renderer: Mesa DRI Intel® Ironlake Desktop
When I try to view something I get
MESA_GL_VERSION_OVERRIDE=3.2 paraview 50grains128x128x128_00.vtr
Segmentation fault (core dumped)
Looks like your hardware is not suported, you can try with mesa/llvm instead.
paraview --mesa
Thank you for helping out, I got the following
The pop up window gave
Your OpenGL drivers don’t supportrequired OpenGL features for basic rendering.
Application cannot continue. Please exit and use an older version.
OpenGL Vendor:
OpenGL Version:
OpenGL Renderer:
On the terminal however more information, can you glean something from it
ERROR: In /home/abuild/rpmbuild/BUILD/ParaView-v5.4.1/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 831
vtkXOpenGLRenderWindow (0x55a546149410): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2.
ERROR: In /home/abuild/rpmbuild/BUILD/ParaView-v5.4.1/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.cxx, line 816
vtkXOpenGLRenderWindow (0x55a546149410): failed to create offscreen window
ERROR: In /home/abuild/rpmbuild/BUILD/ParaView-v5.4.1/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 819
vtkXOpenGLRenderWindow (0x55a546149410): GLEW could not be initialized.
Can you run ./bin/vtkProbeOpenGLVersion if it is available?
If not, try running glxinfo | grep OpenGL
Looks like you using mesa with an old driver.
You need to make sure your drivers supports mesa and llvm is installed correctly.
OpenGL renderer string: Mesa DRI Intel® Ironlake Desktop
OpenGL extensions:
Instead of updating your local llvm, you can use the llvm that ships with ParaView. Try running with
paraview --mesa-llvm
I think Cory’s suggestion is correct. However, ParaView’s error messages (and advice) needs clarification. I wrote up a feature request here: https://gitlab.kitware.com/paraview/paraview/issues/18549.
*** on the pop up window
OpenGL Vendor:
OpenGL Version:
OpenGL Renderer:
*** and on the command line
vtkXOpenGLRenderWindow (0x55a7ac835910): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2.
I am having a similar problem as stated. But I am using a virtual machine instead. My OpenGL version is string:2.1 Mesa 18.0.5. My ubuntu version is the latest one at the moment. 18.04.01 Lts version. I have enabled 3D
VirtualBox does not provide a sufficient version of OpenGL for ParaView.
i am having the same problem too with opensuse leap 15.2 paraview 5.8
OpenGL Version: 2.1 Mesa 19.3.4
OpenGL Renderer: Mesa DRI Intel® Ironlake Mobile
See here : How to run ParaView (including the binary release) using Mesa on Windows
i am using opensuse not windos please is there a solution ??
