Hi
I’m new paraview user. I installed the latest version 5.8 on windows 10 with nividia quadro 2000M graphic card. When executed with GPU, it launches and allow to open a vtk file but it displays nothing in graphic window. I tried older versions, reinstalled and updated drivers but nothing changed.
Thank you for your help
Thanks for your reply.
I have a second PC with windows7 and Nvidia GeForce GT620M where I use (for a couple of weeks now) Paraview to post-process results of OpenFOAM and DualSphysics simulations.
I use 2 versions of paraview which work fine. One under BlueCFD (linux like environement) and the second is under windows. In this win7 machine, all V5 paraview versions are working well.
This is the displayed errors when Paraview is launched with CPU option
and this is what is displayed when it launched with GPU
See the responses to this recent question as they may be relevant. Especially read the last few responses about specifying the graphics card manually for ParaView. If that doesn’t work there’s not much more advice I can give - you may have to wait on someone from Kitware to get back to you.
Thank you very much Greg Vernon
Finally my problem is fixed by installing paraview 5.8RC1. I don’t know why 5.8RC2 is not compatible with Nvidia Quadro
@cory.quammen @utkarsh.ayachit : Should we check RC2 on a windows + quadro setup ?
I’m confused - all your data sources are marked as not visible in the image of the Pipeline Browser when using the GPU. You shouldn’t see anything in the render view. Make those visible and you will see objects rendered. If that is not the case, please include a screenshot of the entire application window.
I have a Quadro M4000 (NVIDIA driver version 431.70) on which I test all Windows release candidates. I haven’t seen this problem with any of the four Windows binary packages of 5.8.0-RC2.
Thanks Cory
I couldn’t make them visible. They become disabled as I click on one of the icons. My Graphic Card is Quadro 2000M with driver version 377.83
Here are the screenshots :
@seghir @cory.quammen RC2, Windows, works for me.
@segir, thanks for the screenshots. Let’s see what graphics implementation ParaView is using.
Could you screenshot the “About ParaView” dialog after starting up 5.8.0-RC2 (Help menu, About ParaView)?
It looks like are running in a VMWare virtual machine. Are you able to run ParaView 5.8.0-RC1 in that same environment?
Hmm, that is strange that it took an uninstall and reinstall, but I’m glad it is working now.
Does an uninstall remove configuration files?
The cross-hatching appearance is just z-fighting which is what you get when you show two nearly exactly overlapping surfaces.
If you get to a state where you can consistently reproduce a crash, please let us know how you did so.
@cory.quammen : VMWare in the about dialog only means that he is using mesa. You will get the same results when running paraview-mesa paraview
@seghir : You GPU driver was somehow not detected and ParaView was falling back to mesa, which was failing to render for some reason.
About your crash, please provide steps to reproduce.
