gpuligundla
(Geethakrishna Puligundla)
March 1, 2024, 10:51pm
1
Hi, I’m using Paraview super build.But my build setup fails with below error
FAILED: VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/proj_json_streaming_writer.cpp.o
My cmake command is cmake -GNinja -DENABLE_osmesa=ON -DENABLE_mpi=ON -DENABLE_paraview=ON -DCMAKE_BUILD_TYPE=Release ../paraview-superbuild/
gpuligundla
March 2, 2024, 12:02am
2
More info
[7555/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/proj_json_streaming_writer.cpp.o
/usr/bin/c++ -DMUTEX_pthread -DNOMINMAX -DVTK_RELATIVE_DATADIR=\"share/vtk-pv5.11/proj\" -Dlibproj_EXPORTS -I/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src -I/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/include -I/tmp/osmesa/superbuild/paraview/build/VTK/ThirdParty/libproj/vtklibproj/src -I/tmp/osmesa/superbuild/paraview/build/VTK/ThirdParty/nlohmannjson/vtknlohmannjson -I/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/nlohmannjson/vtknlohmannjson -I/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/nlohmannjson/vtknlohmannjson/include -isystem /tmp/osmesa/superbuild/paraview/build/VTK/ThirdParty/libproj -isystem /tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj -isystem /tmp/osmesa/superbuild/paraview/build/VTK/ThirdParty/nlohmannjson -isystem /tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/nlohmannjson -isystem /tmp/osmesa/superbuild/paraview/build/VTK/ThirdParty/sqlite -isystem /tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/sqlite -isystem /tmp/osmesa/install/include -fPIC -std=c++11 -O3 -DNDEBUG -std=c++11 -fPIC -fvisibility=hidden -fvisibility-inlines-hidden -MD -MT VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/proj_json_streaming_writer.cpp.o -MF VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/proj_json_streaming_writer.cpp.o.d -o VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/proj_json_streaming_writer.cpp.o -c /tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp
In file included from /tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:34:
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:42:14: error: ‘int64_t’ in namespace ‘std’ does not name a type
42 | typedef std::int64_t GIntBig;
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:43:14: error: ‘uint64_t’ in namespace ‘std’ does not name a type; did you mean ‘wint_t’?
43 | typedef std::uint64_t GUInt64;
| wint_t
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:93:14: error: ‘GIntBig’ has not been declared
93 | void Add(GIntBig nVal);
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:93:10: error: ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’ cannot be overloaded with ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:91:10: note: previous declaration ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’
91 | void Add(int nVal) { Add(static_cast<GIntBig>(nVal)); }
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:94:14: error: ‘GUInt64’ has not been declared
94 | void Add(GUInt64 nVal);
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:94:10: error: ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’ cannot be overloaded with ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp: In member function ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(int)’:
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:91:42: error: ‘GIntBig’ does not name a type
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp: In member function ‘void vtklibproj_osgeo::proj::CPLJSonStreamingWriter::Add(unsigned int)’:
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.hpp:92:51: error: ‘GIntBig’ does not name a type
92 | void Add(unsigned int nVal) { Add(static_cast<GIntBig>(nVal)); }
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp: At global scope:
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:45:14: error: ‘uint64_t’ in namespace ‘std’ does not name a type; did you mean ‘wint_t’?
45 | typedef std::uint64_t GUIntBig;
| wint_t
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:238:6: error: variable or field ‘Add’ declared void
238 | void CPLJSonStreamingWriter::Add(GIntBig nVal)
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:238:34: error: ‘GIntBig’ was not declared in this scope
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:244:6: error: variable or field ‘Add’ declared void
244 | void CPLJSonStreamingWriter::Add(GUInt64 nVal)
/tmp/osmesa/superbuild/paraview/src/VTK/ThirdParty/libproj/vtklibproj/src/proj_json_streaming_writer.cpp:244:34: error: ‘GUInt64’ was not declared in this scope
[7556/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/tsfn.cpp.o
[7557/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/units.cpp.o
[7558/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/sqlite3_utils.cpp.o
[7559/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/zpoly1.cpp.o
[7560/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/conversions/axisswap.cpp.o
[7561/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/filemanager.cpp.o
[7562/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/grids.cpp.o
[7563/19790] Building CXX object VTK/ThirdParty/libproj/vtklibproj/src/CMakeFiles/libproj.dir/networkfilemanager.cpp.o
[7564/19790] Generating proj.db
ninja: build stopped: subcommand failed.
CMake Error at /tmp/osmesa/superbuild/sb-paraview-build.cmake:47 (message):
Failed with exit code 1
ben.boeckel
(Ben Boeckel (Kitware))
March 2, 2024, 9:58pm
3
What compiler are you using? Looks like we need to add an include to libproj. What version of ParaView and the superbuild are you using?
gpuligundla
March 2, 2024, 10:02pm
4
i’m using
gcc (Ubuntu 13.2.0-4ubuntu3) 13.2.0
g++ (Ubuntu 13.2.0-4ubuntu3) 13.2.0
for super build v5.11.2-1
Can you help me with a workaround/fix, i want to setup Paraview in my server ASAP
gpuligundla
March 2, 2024, 10:06pm
5
My actual issue is of I'm using Ubuntu 22 and ParaView osmesa binary crashes on rendering
My server is of AMD, so I cant use EGL. I’m left with superbuild.
Which is too causing issues for me.
I want to build a headless Paraview for pvserver, let me know which super build version is stable to build it and use
mwestphal
(Mathieu Westphal (Kitware))
March 4, 2024, 8:30am
6
5.12.0 or master will be your best bet.
gpuligundla
March 4, 2024, 7:11pm
7
its happening in 5.12.0too
mwestphal
March 8, 2024, 9:16am
9
using ParaView-Superbuild master and paraview master works great here.
ben.boeckel
April 1, 2024, 8:51pm
10
It was fixed on master in this MR but was not put onto any release branch as updating third party projects on just-release branches runs into this issue .
