Need to use paraviewweb with NVIDIA index support. I’ve followed the guide from ParaView | NVIDIA NGC and downloaded nvcr.io/nvidia-hpcvis/paraview:egl-py3-5.9.0 image.
Launched it by using the command
docker run --gpus all -p 8080:8080 -v C:/Users/user/Documents/pvw-data:/data \
nvcr.io/nvidia-hpcvis/paraview:egl-py3-5.9.0 \
./bin/pvpython share/paraview-5.9/web/visualizer/server/pvw-visualizer.py \
--content share/paraview-5.9/web/visualizer/www/ --port 8080 --data /data
Got the error
( 3.326s) [paraview ] vtkShaderProgram.cxx:452 ERR| vtkShaderProgram (0x55ae7531d940): 1: #version 140
2: #ifdef GL_ES
3: #ifdef GL_FRAGMENT_PRECISION_HIGH
4: precision highp float;
5: precision highp sampler2D;
6: precision highp sampler3D;
7: #else
8: precision mediump float;
9: precision mediump sampler2D;
10: precision mediump sampler3D;
11: #endif
12: #define texelFetchBuffer texelFetch
13: #define texture1D texture
14: #define texture2D texture
15: #define texture3D texture
16: #else // GL_ES
17: #define highp
18: #define mediump
19: #define lowp
20: #if __VERSION__ == 150
21: #define texelFetchBuffer texelFetch
22: #define texture1D texture
23: #define texture2D texture
24: #define texture3D texture
25: #endif
26: #endif // GL_ES
27: #define varying in
28:
29: out vec4 fragOutput0;
30:
31: void main(void) {
32: fragOutput0 = vec4(float(gl_PrimitiveID)/100.0,1.0,1.0,1.0);
33: }
( 3.327s) [paraview ] vtkShaderProgram.cxx:453 ERR| vtkShaderProgram (0x55ae7531d940): 0:32(27): error: `gl_PrimitiveID' undeclared
0:32(21): error: cannot construct `float' from a non-numeric data type
0:32(21): error: operands to arithmetic operators must be numeric
0:32(16): error: cannot construct `vec4' from a non-numeric data type
Some datasets can be opened and rendered. But after I’ve enabled Point Gaussian representation on the dataset I got server crash with the error:
35.019s) [paraview ] vtkShaderProgram.cxx:468 ERR| vtkShaderProgram (0x55d092aea580): 1: #version 140
2: #ifdef GL_ES
5: #else
6: precision mediump float;
7: #endif
8: #else // GL_ES
9: #define highp
10: #define mediump
11: #define lowp
12: #endif // GL_ES
13:
14:
15: /*=========================================================================
16:
17: Program: Visualization Toolkit
18: Module: vtkPointGaussianGS.glsl
19:
20: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
21: All rights reserved.
22: See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
23:
24: This software is distributed WITHOUT ANY WARRANTY; without even
25: the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
26: PURPOSE. See the above copyright notice for more information.
27:
28: =========================================================================*/
29: // Template for the polydata mappers geometry shader
30:
31: // primitiveID
32: //VTK::PrimID::Dec
33:
34: // optional color passed in from the vertex shader, vertexColor
35: //VTK::Color::Dec
36:
37: layout(points) in;
38: layout(triangle_strip, max_vertices = 3) out;
39:
40: uniform int cameraParallel;
41: uniform float triangleScale;
42:
43: uniform mat4 VCDCMatrix;
44:
45: in float radiusVCVSOutput[];
46: out vec2 offsetVCGSOutput;
47:
48: // clipping plane vars
49: //VTK::Clip::Dec
50:
51: // picking support
52: //VTK::Picking::Dec
53:
54: void main()
55: {
56: // the offsets sent down are positioned
57: // as radius*triangleScale from the center of the
58: // gaussian. This has to be consistent
59: // with the offsets we build into the VBO
60: float radius = radiusVCVSOutput[0]/triangleScale;
61:
62: int i = 0;
63: vec4 offset;
64:
65: vec4 base1 = vec4(1.0,0.0,0.0,0.0);
66: vec4 base2 = vec4(0.0,1.0,0.0,0.0);
67:
68: // make the triangle face the camera
69: if (cameraParallel == 0)
70: {
71: vec3 dir = normalize(-gl_in[0].gl_Position.xyz);
72: base2 = vec4(normalize(cross(dir,vec3(1.0,0.0,0.0))), 0.0);
73: base1 = vec4(cross(base2.xyz,dir),0.0);
74: }
75:
76: gl_PrimitiveID = gl_PrimitiveIDIn;
77:
78: //VTK::Clip::Impl
79:
80: //VTK::Color::Impl
81:
82: // note 1.73205 = 2.0*cos(30)
83:
84: offset = vec4(-1.73205*radiusVCVSOutput[0], -radiusVCVSOutput[0], 0.0, 0.0);
85:
86: //VTK::Picking::Impl
87:
88: offsetVCGSOutput = offset.xy/radius;
89: gl_Position = VCDCMatrix * (gl_in[0].gl_Position + offset.x*base1 + offset.y*base2);
90: EmitVertex();
91:
92: offset = vec4(1.73205*radiusVCVSOutput[0], -radiusVCVSOutput[0], 0.0, 0.0);
93: offsetVCGSOutput = offset.xy/radius;
94: gl_Position = VCDCMatrix * (gl_in[0].gl_Position + offset.x*base1 + offset.y*base2);
95: EmitVertex();
96:
97: offset = vec4(0.0, 2.0*radiusVCVSOutput[0], 0.0, 0.0);
98: offsetVCGSOutput = offset.xy/radius;
99: gl_Position = VCDCMatrix * (gl_in[0].gl_Position + offset.x*base1 + offset.y*base2);
100: EmitVertex();
101:
102: EndPrimitive();
103: }
( 35.019s) [paraview ] vtkShaderProgram.cxx:469 ERR| vtkShaderProgram (0x55d092aea580): Could not create shader object.
Loguru caught a signal: SIGSEGV
Stack trace:
[truncated]
123 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
122 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
121 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
120 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
119 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
118 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
117 0x7f736099d0fc /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c0fc) [0x7f736099d0fc]
116 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
115 0x7f73609a2225 _PyEval_EvalFrameDefault + 15845
114 0x7f7360a88768 PyObject_Call + 72
113 0x7f7360a5ce36 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x23be36) [0x7f7360a5ce36]
112 0x7f736099d4ce PyEval_EvalCodeEx + 62
111 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
110 0x7f73609a2225 _PyEval_EvalFrameDefault + 15845
109 0x7f7360a88768 PyObject_Call + 72
108 0x7f7360a886fd _PyObject_Call_Prepend + 205
107 0x7f7360a87fd1 _PyObject_FastCallDict + 305
106 0x7f736099cc8d _PyFunction_FastCallDict + 317
105 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
104 0x7f73609a2225 _PyEval_EvalFrameDefault + 15845
103 0x7f7360a88768 PyObject_Call + 72
102 0x7f7360a886fd _PyObject_Call_Prepend + 205
101 0x7f7360a87fd1 _PyObject_FastCallDict + 305
100 0x7f736099cc8d _PyFunction_FastCallDict + 317
99 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
98 0x7f73609a2225 _PyEval_EvalFrameDefault + 15845
97 0x7f7360a88768 PyObject_Call + 72
96 0x7f7360a886fd _PyObject_Call_Prepend + 205
95 0x7f7360a87fd1 _PyObject_FastCallDict + 305
94 0x7f736099ce25 _PyFunction_FastCallDict + 725
93 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
92 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
91 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
90 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
89 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
88 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
87 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
86 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
85 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
84 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
83 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
82 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
81 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
80 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
79 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
78 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
77 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
76 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
75 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
74 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
73 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
72 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
71 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
70 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
69 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
68 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
67 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
66 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
65 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
64 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
63 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
62 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
61 0x7f736099d0fc /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c0fc) [0x7f736099d0fc]
60 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
59 0x7f73609a2225 _PyEval_EvalFrameDefault + 15845
58 0x7f7360a88768 PyObject_Call + 72
57 0x7f7360a5ce36 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x23be36) [0x7f7360a5ce36]
56 0x7f736099d4ce PyEval_EvalCodeEx + 62
55 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
54 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
53 0x7f736099d1ec /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c1ec) [0x7f736099d1ec]
52 0x7f7360a3453b _PyCFunction_FastCallDict + 443
51 0x7f73479afc22 vtkPythonOverload::CallMethod(PyMethodDef*, _object*, _object*) + 1682
50 0x7f73156183df /opt/paraview/lib/python3.6/site-packages/vtkmodules/vtkCommonCore.so(+0x1513df) [0x7f73156183df]
49 0x7f736040aee2 /opt/paraview/lib/libvtkCommonCore-pv5.9.so.1(+0x40dee2) [0x7f736040aee2]
48 0x7f73479ae07b vtkPythonCommand::Execute(vtkObject*, unsigned long, void*) + 411
47 0x7f7360a88768 PyObject_Call + 72
46 0x7f7360a5cd6b /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x23bd6b) [0x7f7360a5cd6b]
45 0x7f736099d4ce PyEval_EvalCodeEx + 62
44 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
43 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
42 0x7f736099d0fc /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c0fc) [0x7f736099d0fc]
41 0x7f736099ca0f /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17ba0f) [0x7f736099ca0f]
40 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
39 0x7f736099d2be /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c2be) [0x7f736099d2be]
38 0x7f736099b803 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17a803) [0x7f736099b803]
37 0x7f73609a3303 _PyEval_EvalFrameDefault + 20163
36 0x7f736099d1ec /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x17c1ec) [0x7f736099d1ec]
35 0x7f7360a3453b _PyCFunction_FastCallDict + 443
34 0x7f730081d7b3 /opt/paraview/lib/python3.6/site-packages/paraview/modules/vtkPVClientWeb.so(+0x27b3) [0x7f730081d7b3]
33 0x7f73006127e1 vtkPVWebApplication::StillRenderToBuffer(vtkSMViewProxy*, unsigned long, int) + 17
32 0x7f730061255f vtkPVWebApplication::StillRender(vtkSMViewProxy*, int) + 383
31 0x7f735d452acb vtkSMViewProxy::CaptureWindow(int, int) + 91
30 0x7f735d4518f6 /opt/paraview/lib/libvtkRemotingViews-pv5.9.so.1(+0x2638f6) [0x7f735d4518f6]
29 0x7f735d4514d7 vtkSMViewProxy::CaptureWindowSingle(int, int) + 71
28 0x7f735d450db2 vtkSMViewProxy::CaptureWindowInternal(int, int) + 754
27 0x7f735d40edcc vtkSMRenderViewProxy::RenderForImageCapture() + 92
26 0x7f735d45083b vtkSMViewProxy::StillRender() + 347
25 0x7f736377bdf5 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 53
24 0x7f736377cebb vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 75
23 0x7f736377d092 vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) + 242
22 0x7f7362ad573d vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) + 29
21 0x7f7362ad536e vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) + 1454
20 0x7f7362ad4afe vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) + 1614
19 0x7f7362ad431e vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) + 478
18 0x7f73640e64e8 vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 9464
17 0x7f735d3a87ff vtkPVRenderView::StillRender() + 111
16 0x7f735d3b4cc2 vtkPVRenderView::Render(bool, bool) + 2082
15 0x7f734dfc1848 vtkOpenGLRenderWindow::Render() + 184
14 0x7f734b630677 vtkRenderWindow::Render() + 311
13 0x7f734b62fc85 vtkRenderWindow::DoStereoRender() + 213
12 0x7f734b6429bf vtkRendererCollection::Render() + 207
11 0x7f734b63c3f5 vtkRenderer::Render() + 3173
10 0x7f734dfc858f vtkOpenGLRenderer::DeviceRender() + 159
9 0x7f734df0499e vtkCameraPass::Render(vtkRenderState const*) + 622
8 0x7f734dfc6385 vtkOpenGLRenderer::UpdateGeometry(vtkFrameBufferObjectBase*) + 3125
7 0x7f734dfc91aa vtkOpenGLRenderer::DeviceRenderOpaqueGeometry(vtkFrameBufferObjectBase*) + 618
6 0x7f734b639e26 vtkRenderer::DeviceRenderOpaqueGeometry(vtkFrameBufferObjectBase*) + 86
5 0x7f734b57f80f vtkActor::RenderOpaqueGeometry(vtkViewport*) + 719
4 0x7f734df35147 vtkOpenGLActor::Render(vtkRenderer*, vtkMapper*) + 279
3 0x7f734df87b64 vtkOpenGLPointGaussianMapper::Render(vtkRenderer*, vtkActor*) + 772
2 0x7f734df85347 vtkOpenGLPointGaussianMapper::RenderInternal(vtkRenderer*, vtkActor*) + 519
1 0x7f734df9dfe0 vtkOpenGLPolyDataMapper::UpdateShaders(vtkOpenGLHelper&, vtkRenderer*, vtkActor*) + 1248
0 0x7f7365425040 /lib/x86_64-linux-gnu/libc.so.6(+0x3f040) [0x7f7365425040]
( 35.019s) [paraview ] :0 FATL| Signal: SIGSEGV
On the host machine I’ve got RTX 3050 NVIDIA card with 511.65 driver version, which should be enough from the perspective of CUDA support.
What could be the reason for that issue and how to fix it?
