In ParaView 5.5.2, I saved the Save State as a py file, but found that the proxy name was not saved. How can I save the name?
Best regards.
Best regards.
Hmm, that’s an interesting request. The variables that hold references to various sources are based off the names of the sources, but I assume that’s not sufficient. There isn’t a way to write out the proxy names when you save the state in Python, but you can retrieve the source name with
sources = GetSources()
sources.keys()[sources.values().index(s)][0]
where s is a source of interst.
Thank you very much for your help, thank you!
If I want to create a Sphere in Python code, can I specify the proxy name when I create sphere? Instead of renaming it after creation is done like this:
Cone = Cone()
RenameSource(“AAA”, cone)
Thank you!
Yes, it is possible.
cone = Cone(registrationName="AAA")
Hello! Thank you very much for your reply!
When ParaView was designed, did you consider internationalization to support multiple languages? I need to support Chinese now, but the project can’t generate Qt .ts file; when the Proxy Name is Chinese, save state generates pvsm file without any problem, but the py file will generate an error.
So, does ParaView have a special handling solution?
thank you very much!
Sadly, this would require a great amount of work. See here for more info :
