Hello, Has anyone successfully read data from an HDF5 file? I am having difficulties reading in my data which contains ~100 data slices. I can put my H5 into Paraviews pipeline, it will recognize the path within the H5 file but when I hit apply to load/ render the data I get hit with a slew of errors. I am most likely doing something incorrectly when it comes to loading/rendering.
HDF5 is not, in itself, a format.
ParaView supports a few formats based on HDF5 :
TRUCHAS HDF5 (.h5 files)
VERA OUT HDF5 (.h5 files)
H5Part (.h5part files)
ENZO AMR particles (.boundary .hierarchy files)
Xdmf2 (.xmf files)
Xdmf3 (.xmf files)
The most popular of these formats with ParaView is Xdmf2. It is also well documented, so I would suggest using that. Of course, that depends of the actual format of your data.
