I was attempting to set up a pvserver pvsc file as per this post using Paraview 5.8.0.
Currently, I can successfully manually start a client-server process using:
ssh user@remote -L 11150:localhost:11111 /home/user/run_pvserver.sh -g
then manually connect to localhost:11150 using the Client / Server setting.
So I tried to make a pvsc file with the following:
<Servers>
<Server name="serverSSH" resource="cs://remote:11111">
<CommandStartup>
<SSHCommand exec="/home/user/run_pvserver.sh -- " timeout="0" delay="5">
<SSHConfig user="user">
<Terminal/>
<PortForwarding local="11150"/>
</SSHConfig>
<Arguments>
<Argument value="$PV_SERVER_PORT$"/>
</Arguments>
</SSHCommand>
</CommandStartup>
</Server>
</Servers>
But on loading and attempting to connect, I get the following error:
# Option “-e” is deprecated and might be removed in a later version of gnome-terminal.
# Use “-- ” to terminate the options and put the command line to execute after it.
# Failed to parse arguments: Unknown option -L
Command aborted.
Did I make a mistake in my file?
Thanks and regards,
Tim
