Using VR device add a crop plane to crop a 3D model, the remained model is not solid
Hello Everyone
i want to Add a crop plane through the VR device, and the cropped model is solid
I’m using ParaView 3.13.0 to visualize a model.vtu file
with the XRInterface plugin, steamVR is runtime, HMD is HTC vive
using Add Crop Plane operation
like this
moving the model across red box, the result like this
As you can see, the interior of the model is not rendered, in short, the model is not solid after cropping.
If I perform the crop operation in the paraview, then the model after the crop is solid
Hi @JIERSHAO
As you point out, the crop plane is not doing a slice operation as the clip filter does.
It sadly is not supported (yet) to do an true interactive clip in VR, however if you use the “Shrink” filter with a factor of 1, you can approximate the behavior and see internal cells.
I hope this helps,
think you for your reply, but I made an expression error in the previous question. I am using ParaView 5.13.0, not ParaView 3.13.0.
So, If I am using the ParaView 5.13 series with the XRInterface plugin, can the remaining part of the model be solid after performing the “add crop plane” operation to crop the 3D model?
Bonjour Monseur!
i tried to use the “Shrink” filter with a factor of 1. The results before and after the “Add crop plane” operation are shown in the following figure:
As we can see, by using “Shrink” filiter, after cropping the model, The model has some small pieces. But the results of rendering looks like a beehive. In fact, all I need to do is render this cutting surface.
For examples, as shown in the following figure, using "clip"operation in ParaView, it just renders the cutting surface.
Thanks again for your patience in replying!
I’m afraid this is not supported, but it would be very nice to add this!
Sorry to jump in here. VR options are done using openVR or OpenXr? I read that openXR is no longer maintained since 2024, is this true? What do you suggest to use and install? Thanks.-
i use OpenXR option, choose OpenVR option is also ok.
From what I understand, OpenXR is supposed to be the key technical solution and will not stop being maintained.
you can share the artical or web site about this news.
just need install paraview5.13.0 and steamVR
Bonjour Monsieur!
You can also briefly describe the purpose of using OpenXR, perhaps we have a similar direction to work in
Hi, this is one of the many news I read [Quickstart | OpenXR Toolkit]
Hi, my supervisor wants to render results in Paraview using virtual reality headsets and controls. I am not attached to any system VR or XR, just want something that works in my machine. Did you download Paraview 5.13.0, superbuild?
OpenVR is legacy, OpenXR is actively devleoped and maintained.
Please open your own topic to get accurate answers :slight_smile:
Sorry for the late reply.
if you want to observe the render results in VR device, just need install paraview.
by XRInterface plugin, send to XR
If you want to do some feature development, I think you might want to clone kitware’s VTK repository. Maybe you need to modify the code in the rendering directory to implement the features you want to develop.
Of course, if it’s something else, you could try the Paraview forums
Hi Mathieu I opened a new question yesterday (I guess) here you have the link to follow [VR Instructions for Vive Pro 2 headset.] Thank you.-
