I found a way to create a quiver3d representation of the velocity field in ParaView using the regular Gliph filter. I changed the Gliph Mode to Every Nth Point (and change the Stride) or all points. I used the 2d Gliph arrow.
I have a couple of questions:
1.Is there a way to use a custom image for the 2d gliphs?
2. I tried to take the quiver figure from Matlab, wrap it as a texture on the object and compare the results. They looked similar but not 100 percent the same.
Does someone have any idea why?
Yes, with a custom dataset, not a custom image. Use the GlyphWithCustomSource filter instead.
It seems that the Gliph arrow generate arrows in the XYZ directions even though the data is in spherical coordinates. Is there a way to show the arrows in spherical coordinates?
The dataset is the same as in my previous question:
I’m sorry but I didn’t understand your answer.
The points are in spherical coordinates and my vector is also in spherical coordinates.
Maybe I missed a Spherical Calculator Filter for spherical objects?
