vtkExodusIIReader: How to Output a Partitioned Dataset Instead of a Multiblock
Dear All,
This post follows up on Mathieu Westphal’s publication regarding the transition from multiblock structures to partitioned datasets: (Transition from multiblock to partitioned datasets in VTK and ParaView, a complete guide)
In that post, it is suggested that using partitioned datasets is preferable to using multiblocks, particulalry to avoid depreciation.
In my case, I’m working with ExodusII files, which I read using the vtkExodusIIReader() class. When I call GetOutput(), it returns a multiblock dataset.
My questions are:
  • Is there a way to directly obtain a partitioned dataset instead of a multiblock from this reader?
  • If so, which command(s) should be used to achieve that?
Any guidance is much appreciated.
Thank you very much !
Momo
Hello @GeoMomo
Use vtkIOSSReader instead of vtkExodusIIReader.
Best,
Thank you for your quick response !
