Allow vtkFileSeriesReader to support multi-output-port readers
Summary
We’ve successfully implemented file series support for a 3-output-port reader by subclassing vtkFileSeriesReader and overriding just the constructor. This works because the base class code is already generic with respect to output count—only the hardcoded SetNumberOfOutputPorts(1) in the constructor limits it to single-port readers. We’d like to request this be made configurable upstream.
Background
We developed the WARPM ParaView Reader Plugin with two reader classes:
vtkWARPMReader- Single output port (standard physical-space data)vtkWARPMPhaseSpaceReader- Three output ports:- Port 0: Physical space mesh
- Port 1: Velocity space mesh (at user-selected location)
- Port 2: Probe position marker
The Problem
When wrapping the 3-port reader with vtkFileSeriesReader using the standard XML pattern:
<SourceProxy name="WARPMPhaseSpaceReader"
class="vtkFileSeriesReader"
si_class="vtkSIMetaReaderProxy"
file_name_method="SetFileName">
<SubProxy>
<Proxy name="Reader" proxygroup="internal_sources"
proxyname="WARPMPhaseSpaceReaderCore" />
</SubProxy>
<OutputPort index="0" name="Physical Space" />
<OutputPort index="1" name="Velocity Space" />
<OutputPort index="2" name="Slice Position" />
</SourceProxy>
…the plugin crashes with a segmentation fault on UpdatePipeline().
Root Cause
Looking at the vtkFileSeriesReader source, the constructor explicitly sets:
this->SetNumberOfOutputPorts(1);
However, the rest of the class (including FillOutputPortInformation, RequestInformation, RequestData, etc.) is written generically and works fine with multiple output ports.
Our Solution
Following the approach described by @Keith_Ballard_CIV in this thread, we created a minimal subclass:
vtkWARPMPhaseSpaceFileSeriesReader.h:
class WARPMREADERCORE_EXPORT vtkWARPMPhaseSpaceFileSeriesReader : public vtkFileSeriesReader
public:
static vtkWARPMPhaseSpaceFileSeriesReader* New();
vtkTypeMacro(vtkWARPMPhaseSpaceFileSeriesReader, vtkFileSeriesReader);
protected:
vtkWARPMPhaseSpaceFileSeriesReader();
~vtkWARPMPhaseSpaceFileSeriesReader() override = default;
vtkWARPMPhaseSpaceFileSeriesReader.cxx:
vtkWARPMPhaseSpaceFileSeriesReader::vtkWARPMPhaseSpaceFileSeriesReader()
// Override base class's SetNumberOfOutputPorts(1) to support 3 outputs
this->SetNumberOfOutputPorts(3);
Updated XML (WARPMReader.xml):
class="vtkWARPMPhaseSpaceFileSeriesReader"
<!-- ... same SubProxy and OutputPort declarations ... -->
</SourceProxy>
Result: File series support works perfectly for our 3-output-port reader. Users can select multiple .h5 files and ParaView treats them as a time series with all three output ports updating correctly.
Feature Request
Since the workaround is so minimal (literally one line in the constructor), would it be possible to make vtkFileSeriesReader configurable for the number of output ports? Options could include:
- Query the internal reader: In
FillOutputPortInformation, if a reader is set, useReader->GetNumberOfOutputPorts()to determine the count - XML attribute: Add an optional attribute like
number_of_output_ports="3"to the ServerManager XML - Constructor parameter: Allow the output port count to be specified at construction time
This would eliminate the need for plugin developers to create trivial subclasses just to change the port count (and need to locate these forum posts revealing the workaround).
Environment
- ParaView 6.0 (built from source)
- VTK 9.5.2
- macOS / Darwin
References
- Our plugin: GitHub - Noerr/warpm-paraview-plugin: ParaView Reader plugin for WARPM discontinuous Galerkin output
- Prior discussion with same workaround: File Series Support for Custom Time-Unaware Plugin
- vtkFileSeriesReader source: paraview/Servers/Filters/vtkFileSeriesReader.cxx at master · certik/paraview · GitHub
Thank you for considering this enhancement!
