Weird display resolution
Description
The display resolution of the GUI changed when I was following up the official tutorial to load and render an ex2 file named disk_out_ref.ex2. Every time I hit the Apply button, things goes weired.
  • Elements of the GUI goes larger
  • Toolbars are missing
  • The render view overlaps with other windows
And interestingly enough, I can still check boxes if I can remember their real locations. It seems that the original GUI is covered by an image.
Environment
Version: ParaView-5.7.0-Windows-Python3.7-msvc2015-64bit.exe
OS: Windows 10 1909 (18363.476)
P.S. I successfully tested the same installer on two other PCs (Win10 1903 and 1909).
This is a known issue with Intel graphics and specific driver versions.
https://gitlab.kitware.com/paraview/paraview/issues/19364
For me, the solution to this problem is to downgrade the intel hd driver.
It worked! Thanks!
I just upgraded my driver to 26.20.100.6913 last month. The upgrades are managed by Lenovo Vantage so I have no idea how to downgrade the driver. I installed version 26.20.100.6709 which overwrote the existing one and paraview now works fine.
Dell XPS 13 w/ Intel HD Graphics 620 + Windows 10 + Paraview 5.8
Upgraded to 26.20.100.7528
old driver was 26.20.100.6951
Problem still persists !
Make sure to reboot.
If problem still persist, upgrade further, or use mesa, or use another GPU.
hello kenichiro, to which version have you downgrade?
best regards
Issue is present between: 26.20.100.6708 <= intel driver < 26.20.100.7528
