mpiexec of pvserver on hosts that are firewalled off to each other ?
I have a number of GPU hosts (hostA, hostB and hostC) which are only accessible via ssh
The following works
hostA$ ssh hostB ls
hostA$ ssh hostC ls
hostA$ mpiexec -hosts hostA /nfs/path/pvserver
The following does not as only port 22 is opened
hostA$ mpiexec -hosts hostA,hostB,hostC /nfs/path/pvserver
Is there some way to setup an ssh tunnel for mpiexec to communicate ?
Cheers
Yes.
Manually:
https://www.paraview.org/Wiki/ParaView:Server_Configuration
Natively in ParaView:
@mwestphal Thank you.
Currently, I am able to connect remotely from my Windows box to a pvserver running on a linux box call LinuxHostA and visualize the data.
[I am currently running pvserver on LinuxHostA only]
ssh -R 8000:localhost:8000 LinuxHostA /home/nyue/systems/Paraview/ParaView-5.9.0-egl-MPI-Linux-Python3.8-64bit/bin/pvserver --reverse-connection --server-port=8000 --client-host=WindowsUserWorkstation
I believe I am making some progress, the Paraview UI indicates parallel/remote rendering
What I am still unable to figure out is how to run the mpiexec on LinuxHostA so that multiple pvserver is launch on e.g. LinuxHostB, LinuxHostC
Using this wiki as a reference, which case should I focus on reading more carefully to formulate the setup run the mpiexec pvserver on the multiple hosts LinuxHostA,LinuxHostB,LinuxHostC with the constraint that the only port number opened is 22 on all the Linux hosts?
Cheers
This would be case height:
https://www.paraview.org/Wiki/ParaView:Server_Configuration#Case_Eight:_Starting_server_using_ssh
But you can just do it manually.
