on my amd processor windows 10 machine paraview does not startup, using AMD Radeon HD 7700 graphics controller.
5.9.1 works well on my windows 10 intel laptop machine
Please try with 5.10-RC2
Thank you Mathieu, I tried 5.10-RC2 (AMD 64). Unfortunately, this did not work.
I can see it startup in the task manager but it disappears quickly.
My PC has both python 3.4.3 (windows) and Ubuntu python 3.8.10 if that makes a difference.
I am willing to buy another graphics controller to use as 2nd controller… any suggestion on which one to purchase?
THanks,
Mike
hard to say, not yet sure this is a graphical problem. Your GPU should be enough.
I would try to do that first:
Tried several of the script like:
openGLInfo = GetOpenGLInformation()
openGLInfo.GetVendor()
openGLInfo.GetVersion()
openGLInfo.GetRenderer()
openGLInfo.GetCapabilities()
I get an error
NameError: name ‘GetOpenGLInformation’ is not defined
As you can see, I am not expert… help please. Mike
you need first to call from paraview.simple import *
When I execute the below on the computer (running python 3.4) that will not run Paraview
I get: ImportError: No module named ‘paraview’
On another computer, that runs paraview, I tried running the same code from a python 3.4 shell and get the same ImportError: No module named ‘paraview’
However, running from the Paraview python shell window the code works!
I am thinking that the Paraview on this machine has it’s own newer version of python and is why the code works.
Upshot is… I can not get the openGLinfo on the machine that won’t load Paraview…
I am spending a lot of time on something that should just work… but I will keep trying.
so, do I need to load a new version of python to get the openGLinfo you requested?
THanks, Mike
You need to run from inside pvpython, which sets up the environment correctly to allow that from paraview.simple import * statement to work.
pvpython.exe is shipped with ParaView, in the bin directory next to paraview.exe
HTH,
Aron
Mistake.
Yes, that did the trick.
Results from machine that won’t start ParaView.
Any suggestions?
Thank you, Mike
Python 3.9.5 (tags/v3.9.5:0a7dcbd, May  3 2021, 17:27:52) [MSC v.1928 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> print(openGLInfo.GetVendor())
ATI Technologies Inc.
>>> print(openGLInfo.GetVersion())
4.5.14831 Core Profile Context 21.5.2 27.20.20903.8001
>>> print(openGLInfo.GetRenderer())
AMD Radeon HD 7700 Series
  GL_AMD_query_buffer_object
  GL_AMD_sample_positions
  GL_AMD_seamless_cubemap_per_texture
  GL_AMD_shader_atomic_counter_ops
  GL_AMD_shader_stencil_export
  GL_AMD_shader_stencil_value_export
  GL_AMD_shader_trinary_minmax
  GL_AMD_sparse_texture
  GL_AMD_stencil_operation_extended
  GL_AMD_texture_cube_map_array
  GL_AMD_texture_texture4
  GL_AMD_transform_feedback3_lines_triangles
  GL_AMD_transform_feedback4
  GL_AMD_vertex_shader_layer
  GL_AMD_vertex_shader_viewport_index
  GL_ARB_ES2_compatibility
  GL_ARB_ES3_1_compatibility
  GL_ARB_ES3_compatibility
  GL_ARB_arrays_of_arrays
  GL_ARB_base_instance
  GL_ARB_bindless_texture
  GL_ARB_blend_func_extended
  GL_ARB_buffer_storage
  GL_ARB_clear_buffer_object
  GL_ARB_clear_texture
  GL_ARB_clip_control
  GL_ARB_color_buffer_float
  GL_ARB_compressed_texture_pixel_storage
  GL_ARB_compute_shader
  GL_ARB_conditional_render_inverted
  GL_ARB_conservative_depth
  GL_ARB_copy_buffer
  GL_ARB_copy_image
  GL_ARB_cull_distance
  GL_ARB_debug_output
  GL_ARB_depth_buffer_float
  GL_ARB_depth_clamp
  GL_ARB_depth_texture
  GL_ARB_derivative_control
  GL_ARB_direct_state_access
  GL_ARB_draw_buffers
  GL_ARB_draw_buffers_blend
  GL_ARB_draw_elements_base_vertex
  GL_ARB_draw_indirect
  GL_ARB_draw_instanced
  GL_ARB_enhanced_layouts
  GL_ARB_explicit_attrib_location
  GL_ARB_explicit_uniform_location
  GL_ARB_fragment_coord_conventions
  GL_ARB_fragment_layer_viewport
  GL_ARB_fragment_program
  GL_ARB_fragment_program_shadow
  GL_ARB_fragment_shader
  GL_ARB_framebuffer_no_attachments
  GL_ARB_framebuffer_object
  GL_ARB_framebuffer_sRGB
  GL_ARB_geometry_shader4
  GL_ARB_get_program_binary
  GL_ARB_get_texture_sub_image
  GL_ARB_gl_spirv
  GL_ARB_gpu_shader5
  GL_ARB_gpu_shader_fp64
  GL_ARB_half_float_pixel
  GL_ARB_half_float_vertex
  GL_ARB_imaging
  GL_ARB_indirect_parameters
  GL_ARB_instanced_arrays
  GL_ARB_internalformat_query
  GL_ARB_internalformat_query2
  GL_ARB_invalidate_subdata
  GL_ARB_map_buffer_alignment
  GL_ARB_map_buffer_range
  GL_ARB_multi_bind
  GL_ARB_multi_draw_indirect
  GL_ARB_multisample
  GL_ARB_multitexture
  GL_ARB_occlusion_query
  GL_ARB_occlusion_query2
  GL_ARB_parallel_shader_compile
  GL_ARB_pipeline_statistics_query
  GL_ARB_pixel_buffer_object
  GL_ARB_point_parameters
  GL_ARB_point_sprite
  GL_ARB_polygon_offset_clamp
  GL_ARB_program_interface_query
  GL_ARB_provoking_vertex
  GL_ARB_query_buffer_object
  GL_ARB_robust_buffer_access_behavior
  GL_ARB_sample_shading
  GL_ARB_sampler_objects
  GL_ARB_seamless_cube_map
  GL_ARB_seamless_cubemap_per_texture
  GL_ARB_separate_shader_objects
  GL_ARB_shader_atomic_counter_ops
  GL_ARB_shader_atomic_counters
  GL_ARB_shader_ballot
  GL_ARB_shader_bit_encoding
  GL_ARB_shader_draw_parameters
  GL_ARB_shader_group_vote
  GL_ARB_shader_image_load_store
  GL_ARB_shader_image_size
  GL_ARB_shader_objects
  GL_ARB_shader_precision
  GL_ARB_shader_stencil_export
  GL_ARB_shader_storage_buffer_object
  GL_ARB_shader_subroutine
  GL_ARB_shader_texture_image_samples
  GL_ARB_shader_texture_lod
  GL_ARB_shader_viewport_layer_array
  GL_ARB_shading_language_100
  GL_ARB_shading_language_420pack
  GL_ARB_shading_language_include
  GL_ARB_shading_language_packing
  GL_ARB_shadow
  GL_ARB_shadow_ambient
  GL_ARB_sparse_buffer
  GL_ARB_sparse_texture
  GL_ARB_spirv_extensions
  GL_ARB_stencil_texturing
  GL_ARB_sync
  GL_ARB_tessellation_shader
  GL_ARB_texture_barrier
  GL_ARB_texture_border_clamp
  GL_ARB_texture_buffer_object
  GL_ARB_texture_buffer_object_rgb32
  GL_ARB_texture_buffer_range
  GL_ARB_texture_compression
  GL_ARB_texture_compression_bptc
  GL_ARB_texture_compression_rgtc
  GL_ARB_texture_cube_map
  GL_ARB_texture_cube_map_array
  GL_ARB_texture_env_add
  GL_ARB_texture_env_combine
  GL_ARB_texture_env_crossbar
  GL_ARB_texture_env_dot3
  GL_ARB_texture_float
  GL_ARB_texture_gather
  GL_ARB_texture_mirror_clamp_to_edge
  GL_ARB_texture_mirrored_repeat
  GL_ARB_texture_multisample
  GL_ARB_texture_non_power_of_two
  GL_ARB_texture_query_levels
  GL_ARB_texture_query_lod
  GL_ARB_texture_rectangle
  GL_ARB_texture_rg
  GL_ARB_texture_rgb10_a2ui
  GL_ARB_texture_snorm
  GL_ARB_texture_stencil8
  GL_ARB_texture_storage
  GL_ARB_texture_storage_multisample
  GL_ARB_texture_swizzle
  GL_ARB_texture_view
  GL_ARB_timer_query
  GL_ARB_transform_feedback2
  GL_ARB_transform_feedback3
  GL_ARB_transform_feedback_instanced
  GL_ARB_transform_feedback_overflow_query
  GL_ARB_transpose_matrix
  GL_ARB_uniform_buffer_object
  GL_ARB_vertex_array_bgra
  GL_ARB_vertex_array_object
  GL_ARB_vertex_attrib_64bit
  GL_ARB_vertex_attrib_binding
  GL_ARB_vertex_buffer_object
  GL_ARB_vertex_program
  GL_ARB_vertex_shader
  GL_ARB_vertex_type_10f_11f_11f_rev
  GL_ARB_vertex_type_2_10_10_10_rev
  GL_ARB_viewport_array
  GL_ARB_window_pos
  GL_ATI_draw_buffers
  GL_ATI_envmap_bumpmap
  GL_ATI_fragment_shader
  GL_ATI_separate_stencil
  GL_ATI_texture_compression_3dc
  GL_ATI_texture_env_combine3
  GL_ATI_texture_float
  GL_ATI_texture_mirror_once
  GL_EXT_abgr
  GL_EXT_bgra
  GL_EXT_bindable_uniform
  GL_EXT_blend_color
  GL_EXT_blend_equation_separate
  GL_EXT_blend_func_separate
  GL_EXT_blend_minmax
  GL_EXT_blend_subtract
  GL_EXT_compiled_vertex_array
  GL_EXT_copy_buffer
  GL_EXT_copy_texture
  GL_EXT_depth_bounds_test
  GL_EXT_direct_state_access
  GL_EXT_draw_buffers2
  GL_EXT_draw_instanced
  GL_EXT_draw_range_elements
  GL_EXT_fog_coord
  GL_EXT_framebuffer_blit
  GL_EXT_framebuffer_multisample
  GL_EXT_framebuffer_object
  GL_EXT_framebuffer_sRGB
  GL_EXT_geometry_shader4
  GL_EXT_gpu_program_parameters
  GL_EXT_gpu_shader4
  GL_EXT_histogram
  GL_EXT_memory_object
  GL_EXT_memory_object_win32
  GL_EXT_multi_draw_arrays
  GL_EXT_packed_depth_stencil
  GL_EXT_packed_float
  GL_EXT_packed_pixels
  GL_EXT_pixel_buffer_object
  GL_EXT_point_parameters
  GL_EXT_polygon_offset_clamp
  GL_EXT_provoking_vertex
  GL_EXT_rescale_normal
  GL_EXT_secondary_color
  GL_EXT_semaphore
  GL_EXT_semaphore_win32
  GL_EXT_separate_specular_color
  GL_EXT_shader_image_load_store
  GL_EXT_shader_integer_mix
  GL_EXT_shadow_funcs
  GL_EXT_stencil_wrap
  GL_EXT_subtexture
  GL_EXT_texgen_reflection
  GL_EXT_texture3D
  GL_EXT_texture_array
  GL_EXT_texture_buffer_object
  GL_EXT_texture_compression_bptc
  GL_EXT_texture_compression_latc
  GL_EXT_texture_compression_rgtc
  GL_EXT_texture_compression_s3tc
  GL_EXT_texture_cube_map
  GL_EXT_texture_edge_clamp
  GL_EXT_texture_env_add
  GL_EXT_texture_env_combine
  GL_EXT_texture_env_dot3
  GL_EXT_texture_filter_anisotropic
  GL_EXT_texture_integer
  GL_EXT_texture_lod
  GL_EXT_texture_lod_bias
  GL_EXT_texture_mirror_clamp
  GL_EXT_texture_object
  GL_EXT_texture_rectangle
  GL_EXT_texture_sRGB
  GL_EXT_texture_sRGB_R8
  GL_EXT_texture_sRGB_RG8
  GL_EXT_texture_sRGB_decode
  GL_EXT_texture_shared_exponent
  GL_EXT_texture_snorm
  GL_EXT_texture_storage
  GL_EXT_texture_swizzle
  GL_EXT_timer_query
  GL_EXT_transform_feedback
  GL_EXT_vertex_array
  GL_EXT_vertex_array_bgra
  GL_EXT_vertex_attrib_64bit
  GL_IBM_texture_mirrored_repeat
  GL_KHR_context_flush_control
  GL_KHR_debug
  GL_KHR_no_error
  GL_KHR_parallel_shader_compile
  GL_KHR_robust_buffer_access_behavior
  GL_KHR_robustness
  GL_KTX_buffer_region
  GL_NV_alpha_to_coverage_dither_control
  GL_NV_blend_square
  GL_NV_conditional_render
  GL_NV_copy_depth_to_color
  GL_NV_copy_image
  GL_NV_depth_buffer_float
  GL_NV_explicit_multisample
  GL_NV_float_buffer
  GL_NV_half_float
  GL_NV_primitive_restart
  GL_NV_shader_atomic_int64
  GL_NV_texgen_reflection
  GL_NV_texture_barrier
  GL_OES_EGL_image
  GL_SGIS_generate_mipmap
  GL_SGIS_texture_edge_clamp
  GL_SGIS_texture_lod
  GL_SUN_multi_draw_arrays
  GL_WIN_swap_hint
  WGL_EXT_swap_control
PixelFormat Descriptor:
depth:  24
class:  TrueColor
buffer size:  32
level:  0
renderType:  rgba
double buffer:  True
stereo:  False
hardware acceleration:  True
rgba:  redSize=8 greenSize=8blueSize=8alphaSize=8
aux buffers:  4
depth size:  24
stencil size:  8
accum:  redSize=0 greenSize=0blueSize=0alphaSize=0
            Please try the following in pvpython:
Sphere()
Show()
Render()
            Hi Mathieu,
I tried these commands on my computer that opens paraview and got a rendered sphere.
On the suspect computer I get this far:
Type “help”, “copyright”, “credits” or “license” for more information.
Sphere()
<paraview.servermanager.Sphere object at 0x0000027515808070>
The next command, Show() causes the command window to close. Tried this several times.
Thanks,
Mike
what is the output of, from a terminal :
glxinfo
glxsphere
            I do not know how to do what you asked…
What do you mean by terminal?
I need hand holding.
Thanks
My bad, I forgot you are on windows.
Please try to update your graphical driver.
Thanks, Yes I tried updating the driver and it says I have the most updated one.
Can we conclude my GPU is the most likely cause for Paraview not starting?
Is there a list of GPU’s tested with Paraview?
Mike
Your GPU should work with ParaView.
All modern GPU are compatible with ParaView.
BTW you can try this solution:
Did not work for me.
Mike
Solved the problem of Paraview not opening on desktop.
I downloaded ParaView-5.8.0-Windows-Python3.7-msvc2015-64bit.exe to try an older version and Paraview appeared on my desktop. Of course, I don’t now why, but I did notice during the install I was asked if I wanted certain packages loaded… Maybe the newer versions should include these?
Mike
