I’ve downloaded ParaView-5.9.1 on my windows 10 laptop. Installation was successful. But when I tried to open Paraview, it was showing a blank white screen. Can you suggest what to do?
please share a screenshot.
Probably graphic driver issue. Please share your GPU and GPU driver currently in use.
I have intel(R) HD graphics 3000 driver installed. There is no external graphics
This is probably the culprit. Please update your GPU driver. If it is still failing, you can take a look at this work around:
If you are running Windows 10 or 11, you have to use mesa OpenGl library from Mesa3D For Windows - Federico Dossena . It will fly
No you dont have to, you should use your GPU driver if possible.
You can use it though, it ever needed, as it is already documented here: How to run ParaView (including the binary release) using Mesa on Windows
