I imported the model into Paraview from another program (it is structural finite element model, which is represented by an unstructured grid), so I have cells and points data.
Please help how to supplement cells data with a column with the external user data (as if adding a column in Excel). I can represent the external data in any way, for example, a csv file, so that each cell corresponds to a value. I need it in order to plot the distribution of user values on the mesh
- Export your data from your software to a .csv
- Open your .csv in ParaView
- Add a TableToPoints filter et check the “Keep All Arrays”, Apply
- Add a Tetrahedralize filter, Apply
- Add a PointDataToCellData filter, Apply
- Click on the PointDataToCellData, press control and click on your dataset to select both
- Add an AppendAttributes filter, Apply
Many thanks for the help!
This solution works without any additions.
The question remained, is it possible to render (using a surface by analogy with stresses, deformations, velocities) this user data on an unstructured grid (assuming the number of user values exactly matches the number of cells)? This question moved to a new topic Render user data on an unstructured grid
